Jump to content
Contest and Giveaways
  • ... Be Sure to Check the --- See Site Contest Giveaways and More in Site Related Below---To See current Contest and Giveaways...
  • Lights of March Contest
Rate this topic
Rate Topic 0
Guest
Debbie can you elaborate a bit more..
You used Rhino Liner to remove stuff off the jeep ?
Or the Rhino liner is coming off the jeep?
I am a bit confused in the wording
What kind of product ?
Share this post
Link to post
Share on other sites
I would try a different approach if its just in a few spots...
I would attempt to sand it with an automatic sander cause thats gonna take some work...
and then patch fill it in and then after that go over it again with a new coat...
Just a thought...
I had to perform some touch up on Lucille and have a couple more spots to Monsta line when I do get her back since I ripped the right rear fender loose and re welded it into position plus I over sprayed a slight amount of black into my red and vice versa...lol It happens...
Good luck
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
